Something that will give an alarm, send a text or otherwise notify when the MyCloud becomes disconnected from the network/router?
Thx.
Thx.
Your MyCloud shouldn’t disconnect from the network…
If it does, there’s something wrong with your MyCloud or your network.
@brooksr Did you set up notifications in Settings? See example image below. Click on, tap or activate image to enlarge it.
I agree that it shouldn’t, but it does. See this thread, I’m not alone: https://community.wd.com/t/mycloud-device-disconnects-itself-from-the-network-daily/92919/25
The MyCloud is connected to the wireless router. Some odd things about this:
Thanks for the suggestion. I will turn the notifications on.
Here are example images, I shutdown and reboot my My Cloud every Thursday.
Click on, tap or activate images to enlarge them.
I would start at your router, and investigate IP address allocation. IME, devices coming and going from a network is often down to IP address conflicts.
