Stuck at updating after system restore reset
Hello, I was shutdown the WD My CLOUD by accident with pulling the cable :frowning:
Then it was stuck for 1 days in initilizing device.
Then i was reseting it the 40 sec way.
Now i come to the point where it says . Getting Starting with an update windows .
I can only do press esc to enter dashboard but still the updating windows appear and I dont do anything.
Anyone have an idea what I can do ?
Its getting an ip address from my router but no access to ssh etc of course
please help
thanks
Hi mossnch1,
The link below will allow you to call support.
