I have a WDTV Live Hub (that I love lol) and am setting up a TV in the bedroom and want to stream stuff stored on the hard drive of the hub to it. Can I just get a WDTV Live (so no storage) and just use it to stream stuff from the Hub over Wifi?
Ideally I’m looking for a setup that doesn’t need to be reconfigured to find the hub every time it’s used…
Yes, the WD TV Live Hub can stream to a WD TV Live or any DLNA/UPnP device. Not only the files in your internal drive, also the files in any USB drive that is connected to the Hub.
thanks for that… sounds like a plan to me
Im sorry if i sound stupid, but i just want to confirm if i have a WDTV live hub set up and connected to a TV in the loungeroom,and then I setup a WDTV live to another tv in another room,that I will beable to watch content off the the livehub on the WDTV live in the other room.
I do hope i make sense.
Any feedback would be great.
