Hi everyone, out of the blue my WD Live Hub stopped working; the player turns on but it can’t link the HDMI channel on my tv and the front WD tag on the player can’t stop flashing. Did anyone have the same problem? Any suggestion? Thanks.
Is the flashing a pattern? Like Three Long, Three Short, Three Long?
If so, the manual says that the Hub has detected a hardware fault.
Yes, it is. Is there a way to fix the hardware fault? I tried to reset the player through the dedicated button but never happened :(
No.
