Having read through the forum, there are obviously some issues with MPEG4/H264, but this one seems strange to me. Would appreciate any help. I have two files that seem pretty close to identical from a technical point of view but first one plays ok (slight audio problem, dropping every 10sec or so but watchable) and the second one which gets a “This file is not supported” message? Media info below…
General
Complete name
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.89 GiB
Duration : 2h 57mn
Overall bit rate : 2 335 Kbps
Encoded date : UTC 2010-02-22 20:07:54
Tagged date : UTC 2010-02-22 20:07:54
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 57mn
Bit rate mode : Variable
Bit rate : 2 020 Kbps
Maximum bit rate : 15.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.091
Stream size : 2.50 GiB (86%)
Writing library : x264 core 84 r1400kGIT 20fa784
Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.0:1.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=4 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=2020 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0 / nal_hrd=1
Encoded date : UTC 2010-02-22 08:15:21
Tagged date : UTC 2010-02-22 20:10:08
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 2h 57mn
Bit rate : 312 Kbps
Maximum bit rate : 431 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 395 MiB (13%)
Encoded date : UTC 2010-02-22 20:09:51
General
Complete name
Format : MPEG-4
Codec ID : isom
File size : 3.27 GiB
Duration : 3h 22mn
Overall bit rate : 2 316 Kbps
Encoded date : UTC 2010-02-24 07:56:37
Tagged date : UTC 2010-02-24 07:56:37
Video
Format : AVC
Codec ID : avc1
Duration : 3h 22mn
Bit rate : 2 000 Kbps
Maximum bit rate : 11.6 Mbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Stream size : 2.82 GiB (86%)
Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.0:1.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=4 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0 / nal_hrd=1
Encoded date : UTC 2010-02-23 17:15:46
Tagged date : UTC 2010-02-24 07:58:55
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 3h 22mn
Bit rate : 312 Kbps
Maximum bit rate : 416 Kbps
Stream size : 451 MiB (13%)
Encoded date : UTC 2010-02-24 07:58:35
