My WD My cloud started acting up yesterday. It had this red indicator light on it. I tried mounting it on USB but it just won’t help. I don’t feel/ hear it running except for the first 30 seconds that I can hear this beeping/ buzzing sound.
Hi thank you for your question. Yes i tried resetting the device, but I’m still getting the red indicator light. As I’ve said I already opened it up and even connecting it via an external enclosure did not work for me.
I’m really curious what the beeping sound that I was hearing. Does it mean that it has mechanical failure? If so what kind? And how do I fix or recover my data? Thank you again.
Hi, I missed the part where you said that you took it out of the enclosure, my bad. :flushed:
After re-hearing the sound with better headphones it does seem to have physical damage. WD have a few Data Recovery patners and some of them can give you a free quote.
My WD EX4100 Raid box beeps once a while for around 30 seconds.
There is nothing wrong with my box. I just wonder why it beeps almost once a day. Is it an alert of intrusion? I found lots of failed login attempt.
