I have had various troubles with the MBL.
I have now noticed that it takes about half an hour (give or take a minute or two) for the status LED to turn solid green. Is this normal, because I seem to recall that it used to be much quicker than this?
While I am gaining experience with this NAS unit I shut it down when not wishing to access it so I can monitor what it is doing when I am present.
After a power up it takes a few minutes to get to blinking green, it then takes a further half an hour to get to solid green, during which time I can hear the read/write heads softly clunking away. The only devices switched on on the network were the modem, router , switch and the MBL. So what is the MBL doing during this time?
