I have a problem with some movies and sound comes as a Digital DTS CAN NOT HER ANYTHING
All other sound configurations are Ok
If ther is anything on the set up to solve this
I am conected with HDMI wire
Thanks in Advance
Thanks in Advance
What type of unit? What version of firmware?
I have same issue: lack of sound with 2 movies one on DTS at 510kbps and another one with AC3 at 640 kbps. Really strange, never happened before until this week. I can run it in my PC with regular codecs.
I have latest firmware and my model is WDBAAN0000NBK-NESN.
Thanks.
I got same problem NO SOUND HELP!!!
WDTV LIVE Model: WDBAAN0000NBK 1.02.21 (3/30/10)
My video Information:
MKV:
VIDEO CODEC: H264 - MPEG-4 AVC
1280 X 544
AUDIO CODEC: DTS 48000HZ BITS 1536 KB/S
P.S. The video sound great in my 4 computers, no sound on wdtv
If the MKV was made with the latest version of mkvmerge the sound will not play on the Live (it can be fixed by remuxing with the appropriate switches – http://community.wdc.com/t5/Firmware/If-your-having-sound-issues-aparently/td-p/32724 ).
I think it’s time for an update to the FAQ. This is going to continue to spread. I’m hoping that’s the issue for the previous two users… because it’s a relatively easy fix…
Sorry I have the WD LIVE and thank for the effort
w00t it works the remux v 4.0
ty alot for the TIP
the solution from the other topic worked just fine!
Just download the old working edition 4.0.0
http://www.bunkus.org/videotools/mkvtoolnix/win32/mkvtoolnix-unicode-4.0.0-setup.exe
run mergemkv and now the sound channel is working! Thanks!
