is14fun
November 8, 2010, 8:21pm
#1
I’m having a problem of sound dropout when playing BluRay MKV files. Everything works find for about 5 or 10 minutes and the sound drops out. I hit stop, rewind a few frames and play and everything is fine for about 5 to 10 minutes and then the same thing happens again. I converted the files with DVD FAB BluRay Copy. Below is a Mediainfo on the file.
I have a first generation WD player with the latest firmware update. Files are stored on a WD 1trig Passport HD.
General
Complete name :
G:\South Pacific\SOUTH PACIFIC.mkv
Format :
Matroska
File size :
34.3 GiB
Duration :
2h 37mn
Overall bit rate :
31.1 Mbps
Encoded date :
UTC 2010-11-07 15:41:59
Writing application :
MakeMKV v1.5.6 beta win(x64-release)
Writing library :
libmakemkv v1.5.6 beta (0.7.7/0.8.1) win(x64-release)
Video
ID :
1
Format :
AVC
Format/Info :
Advanced Video Codec
Format profile :
High@L4.1
Format settings, CABAC :
Yes
Format settings, ReFrames :
4 frames
Muxing mode :
Container profile=Unknown@4.1
Codec ID :
V_MPEG4/ISO/AVC
Duration :
2h 37mn
Bit rate :
30.1 Mbps
Width :
1 920 pixels
Height :
1 080 pixels
Display aspect ratio :
16:9
Frame rate :
23.976 fps
Resolution :
8 bits
Colorimetry :
4:2:0
Scan type :
Progressive
Bits/(Pixel*Frame) :
0.605
Stream size :
33.0 GiB (96%)
Color primaries :
BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics :
BT.709-5, BT.1361
Matrix coefficients :
BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
ID :
2
Format :
AC-3
Format/Info :
Audio Coding 3
Codec ID :
A_AC3
Duration :
2h 37mn
Bit rate mode :
Constant
Bit rate :
448 Kbps
Channel(s) :
4 channels
Channel positions :
Front: L C R, Surround: C
Sampling rate :
48.0 KHz
Stream size :
505 MiB (1%)
Title :
3/1
Language :
English
Text #1
ID :
3
Format :
PGS
Codec ID :
S_HDMV/PGS
Codec ID/Info :
The same subtitle format used on BDs/HD-DVDs
Language :
English
Text #2
ID :
5
Format :
PGS
Codec ID :
S_HDMV/PGS
Codec ID/Info :
Language :
English
Text #3
ID :
7
Format :
PGS
Codec ID :
S_HDMV/PGS
Codec ID/Info :
Language :
English
That’s an extremely high bitrate for an MKV file… That’s my guess…
mkelley
November 8, 2010, 8:32pm
#3
I think you’re right, Tony – and he doesn’t even have a Live, so the buffer is probably even smaller with that first gen player.
I suspect the Live would handle that file.
is14fun
November 9, 2010, 4:23am
#4
What can I do to correct this problem?
Run it through Handbrake’s high profile preset.
mkelley
November 9, 2010, 1:11pm
#6
But do change the output type to MKV (and pass through the AC3/DTS sound track you want).
