I have a problem to use WD Discovery to access the files of my MyCloud Home Duo in RAID 1 mode (20TB Version). Installation is correct and it worked for several years but now the Cloud is not mounting anymore. I do see the „partition“ for timecapsule but not the public part with all my files.
I still can access to all my data via App and Webbrowser but it is not possible there to download more than 50 files at once and it would take years to get all.
Is it possible to connect one of the 2 drives via USB to SATA converter to a laptop to download the whole files or are they encrypted?
Which converter do I need? Does it need a separate power supply (12V). What would you recommend?
I use a Macbook pro and I think this would be the right software: Write/read access to Linux files under macOS High Sierra - extFS by paragon software for Mac
Are the files encrypted after mounting with paragon?
Or is there another way to get all the files downloaded without selecting each one separately and loading in separate steps?
I really need your help, WD Support can‘t.
Thanks, Markus
