Hi everybody,
It was driving me crazy.
I tried everything an finally it worked for me.
READ EVERYTHING BEFORE THE FIRST CLICK !!! (I told you)
Please do EXACTLY as stefan29 says in message 20 of this thread, in particular do this:
ssh root@mybooklive.local "/etc/init.d/netatalk stop ; rm -v /shares/*/.AppleDB/{*.db;db_*} ; /etc/init.d/netatalk start"
Then do the steps I found in this page by James Pond:
http://pondini.org/TM/A4.html
Next, a literal copy of this particular page (#A4)
" This will reset the connection to your backup destination, and replace the preferences file containing your settings for Time Machine: the destination, options, and any exclusions. If it’s corrupted, Time Machine may not work properly, if at all.
It will not delete anything in your backups, or cause Time Machine to start a new set of backups.
1.On the Time Machine Preferences window, click the Options button. If you have any external HDs that are excluded from backups, connect them temporarily (otherwise those exclusions won’t appear, and you won’t be able to re-enter them in step 5 below).
2.Note everything in the exclusions box, and the settings of the other options (perhaps via a screen print) then click Cancel to return to the main window. Turn Time Machine OFF and quit System Preferences.
3.If you’re backing-up to an external HD, eject, disconnect, and power it off for a few moments, then reconnect it.
4.Delete the file /Library/Preferences/com.apple.TimeMachine.plist (in your top-level Library folder, not your home folder).
(You may have to navigate to it; a Spotlight search won’t show it, and a Finder search won’t, either, unless you include System Files. If you have a problem finding the file, see item #A7.)
5.Go back into Time Machine Preferences, re-select the drive, re-enter any exclusions and other options you noted in step 1. Note that the oldest and latest backup dates won’t appear on this window until the next backup is done.
6.A 120-second countdown to a backup should appear. If you close the window, it should begin immediately. "
NOTE: You must turn the device off waiting at least until it disappears from the finder.
Hope it works for you too
