Some Alternate 'Home Screens' for Hub/SMP
Just a Few Quickly Coded Alternate ’ Home Screens’ For the Live Hub and SMP.
2 of them ‘mede8er’  skinpack conversions + a small tweak “Ambient” one.
Thanks to ‘gerdk’  for the link: http://www.mede8erforum.com/index.php/topic,7539.0.html
 AMBIENT ROOM: http://www.mediafire.com/download.php?xk2wnvzsvafhr5k
BLUE ROOM: http://www.mediafire.com/download.php?ln8rh663ofqsnwt
MOVIE ROOM: http://www.mediafire.com/download.php?h3pcce255l9av0u
Cool - Thanks JoeySmyth
Those look great ,and a nice link to some other interesting choices.
Now if i want to use one of these ,do i simply replace the file in ANY theme or doe it have to be Mochi?
What i mean is ,can i simply delete the image files in current theme and replace them with the files from the Home screen?
                         Thanks a bunch…keep up the good work
JoeySmyth, Congratulations, Good Work
Could you fornener files. psd that you used to make the images, so I edit the images and leave in my language?
Slick work once again JS!
i was a liitle bored, so I have edited one of the above themes,
if anyones interested in this theme… will gladly post it,. if someone can give me a clue on how to do it :wink: thanks.
thanks… ok heres the link  http://www.mediafire.com/?ahrfhpbwc2p34id
mannymiller, great job.
could make one of these in red to match ExtremeMix Coverflow and Sheet 4.0, and it would be possible to make the menus more and fill the screen at the bottom?
Dariod12
how do you mean make the menus more ? the buttons did come on a base which would take them to the bottom of the screen., which did show the very slight mirror effect they have. but prefered them free floating. i was going to add titles to each button, but thought the picture on the tv screen, and icon on button was sufficient. as i said i was bored :smileyvery-happy:. … also it was my first attempt at this.  And credit goes to joeysmyth for supplying the theme in the first place.
Is that the menus in both the main theme of joeysmyth, and on her, are centered on the screen, and left space on both corners of the screen, which I guess is that they are larger and with more space between them so that they meet across the screen, as shown in the picture below screenshot_000.jpg
your picture isnt showing up yet.
so what your saying, is you wish there to be more space between the buttons so they go from side to side… and not just centred, with a space each side ? i can do that… just working on a red variant… will be a while tho, as not bored at the moment… :smileyvery-happy: … pretty busy
That’s right, I think so it is best visible
I’m not hurry if you can do, do according have the time available
thank you
that’s right, I’m waiting in
