I have also the exact same problem…
I have a 8TB qnap ts-412 wired connected with my wdtv thru switch.
the reason i bought the wdtv is for playing music & video files from my NAS and those 2 things don’t work
errors i have:
-when playing let’s say a music folder with 10 songs in it, the first 3 will play, then stops
whatever you try, you can not let another file play (video or music) till you restart the wdtv.
-when playing let’s say a liveset mp3 of 1 hour or longer, the file will play till the end, but… after 10-15minutes
the progress bar and time indcation resets to zero and when you pause or stop, again, you’ll need to restart
the wdtv to be able to play another file
-when playing a movie, again, plays fine till the end if you don’t pause. if you do (before 15minutes, no probs),
restart again or no more playback.
So it seems to me that there’s some kind of bug in wdtv, that appears after about 15 min of non-stop streaming from my nas thru network shares.
I’m shure my qnap is set up right. Never have connection problems with any of the pc’s or my previous mediaplayer.
Also when playing files from my laptop thru network share, same thing happens (just checked it to be shure it wasn’t the qnap)
edit: network share only has this problem, not with files from usb. but like the other guy said, what’s the purpose
of having a server if you still need to copy files over thru usb…
Can somebody please help cause for my use, i have a paperweight in my hands
thanks in advance
edit: searching the net, i find LOTS of people with same problem. they all have nas server and use network share.
this is a core funtion and should be looked at from wdtv dev team
