SOLVED partially MyNet N900 HD and storage options partitions FAT32 and NTFS browsing-viewing
I got usb WD passport III studio II 500GB external disk connected to router MyNet N900 HD.
Got two parttions 200GB FAT32 and 250GB NTFS, but can see-browse with file manager only the one FAT32.
WHY?
Check page 62 of the manual.
http://wdc.com/wdproducts/library/UM/ENG/4779-705072.pdf
thx, but that does not helped me, I can see only the fat32 partition, have done allign the partitions and chcecked for errors trough partition wizard home, but none helped me, whenn I connect the usb to pc there is no problem I can browse all two partitions, but connected the external usb hdd to router I can see-browse only fat32
!!!NEED HELP PLEASE!!!
ok, I managet it out, here is my solution:
  1. on Safely Remove http://192.168.1.1/storage_remove.php I removed with Eject button the usb storage device my III Studio II HDD
  2. on Storage  http://192.168.1.1/storage.php Workgroup Name changed to GROUP1 previous was GROUP
  3. on Host and LAN Settings  http://192.168.1.1/lan.php changed my host name to MyNet900 previous it was MyNet
  4. on DHCP Server Settings  http://192.168.1.1/lan_server.php Local Domain Name changed to GROUP1 previous was group
  5. turned off and turned on again, because router freezed
after then I changed the DHCP Server Settings  http://192.168.1.1/lan_server.php Local Domain Name changed back to GROUP and Storage  http://192.168.1.1/storage.php Workgroup Name changed back to GROUP
and it seems to work but I dont know why it shows as \mynet900\WD_PP_III_Studio_II_01 and \mynet900\WD_PP_III_Studio_II_05 when I have only two partitions on disk and it should show the second partition as \mynet900\WD_PP_III_Studio_II_02 and not …05 ???
