Did you extract all the files to the ROOT of the usb stick ? They shouldn’t be in a directory. Also, like said, you might have to edit that version text file.
Well I did researt but how do I do a system reset exactly? Should the beta drivers definitely fix it?
Ok I just tried it again and I installed the Beta drivers. This time the visuals are fine, not grainey, and its not slow any more, however it is still now showing my network shared folders… Hmmm
I still cannot get the firmware on post 1 of this thread to work. I changed the files as directed but when I put it in, nothing happens. Can anyone perhaps upload the exact files that need to be changed, done properly, do I can try that?
Thanks!
Is your usb drive formatted as FAT32 ? (right click in explorer and you should see ‘FAT32’ as filesystem. If not, format it (quick) as FAT32.
