Soft
I have my Live Hub WD connected to an amplifier/home theatre. Video and photos are ok (and the latter also run ok in my Ipad). But I wonder when are you going to produce a software to “see” the Hub menu from my Ipad, so that I can play music on my home theatre WITHOUT turning on the projector (bc otherwise I cannot see the menu and the folders, which I should be able to do in my Ipad once that software is available).
Regards
Vasco
Your post sounds more like an Idea or a Feature Request. The best
place for this is in our Ideas Lab. This way someone from WD will be
sure to see it. However, I would search first and make sure that
there isn’t another idea similar to yours that you could add your post
to and vote on.
Ideas Lab
http://community.wdc.com/t5/community/categorypage/category-id/idea
