I’m Korean user.
In Korea, smi is used for subtitle instead of srt
WD TV live also support smi file. but there is subtitle bug.
on some smi files support several language, language are mixed.
and can’t select languages.
I think you don’t consider supporting multi languages on old firmware.
So if you fix this problem, I can enjoy more with WD TV live.
Thanks.
firmware : 1.02.21
p.s. there are some misspelled Korean menu.
