I agree, I’d like the option to select folders to backup too. Worse yet I just installed this yesterday. After the first backup two user folders appear to be completely missing. I’ve submitted a problem report and we’ll see what happens. This is on a MyBook, 2TB, Vista, WD Smartware version 1.3.0.16.
This user is not so smart either. The iniitial install had the missing user problem but was running an old version of SmartWare. I updated to the current version after the initial backup. After update I thought the problem was still there, but didn’t notice that the update also turned off backups. I was looking at an old backup and Smartware wasn’t yet adding anything. I needed to also select “Start Backup” after the update. When this was done several minutges ago Smartware found another 43 Gb to backup. The backup is still running but probably everything will be OK when it completes.
