Slow transfer speed issues
i have a Slow transfer speed issues with mybooklive
see the pic
the Max transfer speeds i get is 12MB
it’s connected by Ethernet ,the both mybooklive And my laptop
The same network and the same router ,I have a 4G Router
What is the solution to this problem…!!?
Thanks.
I can’t see your image – I get a 404 error on it.
But it sounds like either your PC or your MBL are actually connected at 100M instead of gig.
What’s a “4G” router?
Hi TonyPh12345,
this is the image …
this is the HUAWEI E5172 4G LTE router
also see this:
As I said, that’s 100mb only. So 12MB per second is the fastest you’ll ever get.
Is there a way to increase speed
For example, buying a new router or something like that
Upgrade your network to Gigabit Ethernet.
i have MSI GT70 with Killer e2200 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
i Found a way to find out if my MSI GT70 supports Gigabit Ethernet or not,
and look at that image:
It’s showing that because your Hauwei gateway is only capable of 100m.
ahaa,
Do you think that this Linksys SE2800 will be the solution
http://www.linksys.com/en-mea/products/switches/SE2800
I don’t know anything about that particular switch, but a gigabit switch in general would be a good idea…
