After updating to 4.00.00-607, my system is very very slow. VERY slow.
I have used the system with apt-get packages, so I know I’m out of warranty, but I think this should still be fixable. I have pretty serious expeirnce with Linux and I have only made a few changes (including installing some apt-get packages in the past)
If not recov erable, what is the best way for a full factory restore with data intact, and as much of the configuration as practical? Or how do I revert to 3.x?
The key observations:
When looking at “top” the system is spending most of its time in IOWAIT
apt-get update never completes.
Data transfer rates are measured in kilobytes/sec, if that. Dtaa transfer to and from the unit is slow. The shell prompt is sluggisg.
The load average is through the roof.
top -
15:01:15 up 1:55, 1 user, load average: 32.24, 25.ls
07, 20.13
Tasks: 131 total, 2 running, 129 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.8 us, 6.8 sy, 0.0 ni, 0.0 id, 89.0 wa , 0.0 hi, 3.4 si, 0.0 st
KiB Mem: 232448 total, 188736 used, 43712 free, 2560 buffers
KiB Swap: 500672 total, 232512 used, 268160 free, 7104 cached
When running the update script from command line, this is the log - if there are any clues.
The warnings are most worrisome:
updateFirmwareFromFile.sh:07/12/14 19:58:23:upgrade start: ./updateFile.deb
updateFirmwareFromFile.sh:07/12/14 19:58:23:check_size=
updateFirmwareFromFile.sh:07/12/14 19:58:24:version_current=040000607
updateFirmwareFromFile.sh:07/12/14 19:58:24:version_newfile=040000607
updateFirmwareFromFile.sh:07/12/14 19:58:24:package_newfile=sq
updateFirmwareFromFile.sh:07/12/14 19:58:24:master_package_name=sq
updateFirmwareFromFile.sh:07/12/14 19:58:24:master_package_new=sq
updateFirmwareFromFile.sh:07/12/14 19:58:24:update_container=
updateFirmwareFromFile.sh:07/12/14 19:58:52:new_upgrade_version=2
updateFirmwareFromFile.sh:07/12/14 19:58:52:current_upgrade_version=2
updateFirmwareFromFile.sh:07/12/14 19:58:52:Newer upgrade scripts in update package, use normal update method
(Reading database … dpkg: warning: files list file for package ‘libssh2-1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libxau6:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘liblockfile1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libkrb5-3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libwrap0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libtagc0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libapr1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libcap2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libglib2.0-0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libgphoto2-port0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libpng12-0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libtalloc2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libevent-2.0-5:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libedit2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libldap-2.4-2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libavahi-client3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libgphoto2-2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libtag1c2a:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘liblua5.1-0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libpkcs11-helper1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libpcre3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libdb5.3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libavahi-common3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libsensors4:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libx11-6:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libnfsidmap2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libbsd0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libavahi-common-data:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libjpeg8:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libnss-winbind:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libsasl2-2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libsasl2-modules:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libcurl3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libaprutil1-ldap:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libtirpc1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libaprutil1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libkrb5support0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘librtmp0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libpcap0.8:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libdevmapper1.02.1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libexpat1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libltdl7:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libkeyutils1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libreadline5:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libantlr3c-3.2-0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libasound2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libxcb1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libtdb1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libxpm4:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libtag1-vanilla:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘liblzo2-2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libogg0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libaprutil1-dbd-sqlite3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libfontconfig1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libmagic1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libk5crypto3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libgssglue1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libjson-c2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libunistring0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libwbclient0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libfuse2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libgssapi-krb5-2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libparted0debian1:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libgd2-xpm:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libconfuse0:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libexif12:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libffi5:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libflac8:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libdbus-1-3:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libxml2:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libfreetype6:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libxdmcp6:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libpam-cap:armhf’ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ‘libpam-winbind:armhf’ missing; assuming package has no files currently installed
24267 files and directories currently installed.)
Preparing to replace sq 04.00.00-607 (using ./updateFile.deb) …
isImage=true
Master package name: sq
sq-preinst: action=upgrade
currentRootDevice=/dev/md0
Save upgrade-version file to /var/lib/dpkg/tmp.ci
/var/lib/dpkg/tmp.ci/upgrade-version' ->
/CacheVolume/upgrade/upgrade-version’
forked-daapd: no process found
disable lazy init
root: disable lazy init
Restore raid device: /dev/sda1
Restore raid device: /dev/sda2
Prepare for upgrade pkg install…
[Message cannto exceed 20000 chars - full file on request]
