Help - what to do…?
Pre - - Indicator lights showed all drives.
Red lIght show degradation was blinking
webpage showed only 3 drives of the 4 - drive 3 was not showing.
Powered unit down
pulled drive 3 out to get the serial number.
powered unit up… all lights test as working during “boot” up.
but then no drive lights light up… the network light is showing as connected on the network. Device does not appear on the network.
Does not show up on the network.
Tried the reset button routine
Pulled the battery.
I was reading things - I’m thinking the firmware should start this puppy up and rebuild?
I tried taking out the bad drive and starting up… still no go.
Any Ideas?
John
