Sharespace connection with Live Hub
#1
Got a quick question for everyone.
Is it possible to connect the WD Sharespace via ethernet cable STRAIGHT to the WD Live Hub Center? I want to stream movies from the sharespace.
Thank you all!
#2
WOW, no one can help me here!
#3
Well, yes, you could do that, but why would you want to?
Just hook them both up to your LAN.
#4
Well the reason is because my network is 10/100 and I figured since both the live hub and sharespace are gigabit interfaces that should be better for streaming than hooking it up to my lan…
Does that make sense?
#5
Yep, your idea sounds perfectly reasonable.
But really it’s not going to make much difference.   The HUB doesn’t do much better than 100 Megabits/second even though it has a Gig interface.   So, in other words, you’re not going to be penalized to any significant degree by keeping it on your existing 100 meg network.
