My WD Product is model#WDBDNK0010BBK-WESN
WD easystore Portable 1 TB
I can’t find the settings for past backups. I want to delete some of them manually.
Hi tess,
You can view or access backed up data in WDBackup.swstor file folder if using WD Backup and it will let you to select files manually. You may refer this KBA to access or view backed up data.
