Please clarify this for me. I have connected two WD 3TB hard drives via a USB Hub to the back of the WD SMP. However I can only access one drive at a time. Meaning the folders of only one drive will show at a time. To access the folders of the other drive I have to go to the ‘Select Content Source’ ‘Local Storage’ (Red Button) and select the other drive. The other drives folders will then load, but I loss the folders of the first drive.
Is this how it should work ? I thought I’d read here were you would see the folders of both drives without having to switch between drives. If so how can I correct this ?
Also, having success with the Wd Elements hard drive I bought a second one. Unfortunately they both show up under the same name ‘Elements’. Is there any way to change that so they show up under different names such as Elements1 and Elements 2.
Thanks…
