Setting Up FTP For Two MBLs On Same Router
I’ve search and searched and cannot find an answer to my problem.
I have two MBLs attached to a Sky Hub.  I’ve given up any hope of getting WD2GO working with Java on Windows 8.1 (if you’ve managed this please tell me how) so I decided to attempt to use FTP to access both MBLs over the net.  This is what I’ve done so far:
I’ve registered a Dynamic DNS with dyn.com
For MBL1 I’ve set up Port Forwarding in the Sky Hub from Port 21 to its static ip address.
I can access this device with ftp://dynmanicdnsaddresss:21
For MBL2 I’ve edited vsftpd.conf:
        listen_port=2121
        pasv_min_port=6000
        pasv_max_port=6099
        and run the command vsftpd restart
Set up Port Forwarding in the Sky Hub from Port 2121 to its static ip address.
I cannot connect to this device using ftp://dynamicdnsaddress:2121.  The server shows the Authentication Required dialogue. Accepts the Username and Password as valid but after several minutes displays  “425 Failed to establish connection”
I really do not know what to do next.  Any help would be greatly appreciated.
Mike
You don’t need to change anything on the MBL.
You only need to have a different EXTERNAL port on your router.
so it’d be
ftp://dynamcicdnsaddress:21     →  Router forwards to port 21 of MBL 1
ftp://dynamcidnsaddress:2121   →  Router forwards to port 21 of MBL 2.
Try that.
Thanks for the suggestion, TonyPh1234,  but I’m afraid it did not work.  A connection was not even established this time.
