Search engine question
Are the files photos safe from search engine? do they get indexed by the search engine? when turning remote access on is there anything else that needs to be done to protect from search engine and privacy. Thanks.
What search engine?? There is an indexing program on the Mirror…and I can’t tell of you are referring to that or not.
I meant like are the documents and photos protected from search engines.
No.  Robots can’t search your Cloud because they can’t log into it.
