Hi folks, due to battery inside device I am looking for Safety Data Sheet (SDS) to proof that hdd is not dangerous for flight.
Thank you, Lukas
Thank you, Lukas
Hi @Lukas_Kolda,
Please be informed that the batteries of My Passport wireless pro are powerful 6,700 mAh battery that can be used to either power up the device (with up to 10 hours of continuous use), or to function as a power bank to provide charging to other devices such as smartphones and tablets.
Please refer to the user manual for more information:
Title User Manual
Link:https://products.wdc.com/library/UM/ENG/4779-706000.pdf
Hi Kerdi,
thank you for your reply, but I need Safety Data Sheet which is separated document from user manual.
It is sheet what is provided to declare capacity, type of batery and some technical details.
Please see example in attachment for my DJI. Same document I’m looking for WD My Passport Wireless Pro
Thank you in advance , Lukas
DJI OM4_MSDS.pdf (1.08 MB)
