Safepoint creation problems
trying to set up safe points… it gives me the option to select local usb or network. it never give me an option to create one. doesnt matter if i chose usb or network. each device on the network shows the same message and never changes…
Which device are you wanting to create a Safepoint for and which device do you want to put it on?
