I’m looking for guidance on how to backup the MyCloud Home. Is there a separate app that I need to install to supports this? If so, what are the name(s) of the apps? Previous generation MyClouds facilitated this with a Safe Point and it doesn’t appear that MyCloud Home has Safe Point functionality?..thanks…John
Hey CatOw…Yes, I have read through the manual. I’m not sure if you
understand my question or are qualified to answer. I’m asking about
backing up the MyCloud home to an external source such as Safe Point
creation was facilitated with MyCloud gen 1. I suppose next you will give
me the obvious answers to scour the knowledge base or WD Community? I wish
I had the last 2 minutes of my life back.
Stay tuned though like that feature may be added pretty soon through firmware update? or more like bring it back to the store and buy the old one?
I need a clarification asap, otherwise I will return it to the store. I feel pretty disappointed about WD for not being able to use a WD my book as a backup to a WD my home cloud.
There is definitely a Safe Point for the MyCloud Home product. If you leave it on the shelf at the Best Buy store, it will not damage your wallet at all. There is a remote chance that it will fall down from that shelf, hurting your feet or toes, but you can minimize that risk by staying away from the aisle that holds these products.
Otherwise, I can tell you I’ve experienced nothing but a disaster from buying this horrible POS product.
