Running Lightroom from Livebook - Possible?
Hi, I have one laptop and intend to buy a PC in a month. Rather than install the software on both can I just access via the NAS? (I am licenced for two machines) this seems like a tidier solution.
Once the application is loaded would there be any performance issues?
Application - Adobe Lightroom, OS Windows 7
Many thanks.
Might be possible if the computers are within the same network. Now, you need to check if the software it self have the options to move files over a network drive.
