I will solve your issue. But first, if you allow me, I would like to advise you NOT to activate the ssh access without sufficient knowledge on linux systems. You will just end up with a dead drive like so many people. When you establish a ssh connection to your drive, you get the following warning:
Failure to understand the Linux command line interface can result in rendering your network device inoperable, as well as allowing unauthorized users access to your network.
This is so true.
Sorry for the off-topic warning. Hopefully, it may benefit others.
Now, I will answer your question:
Let’s take the path you want to acces :
/shares/Public/Shared Pictures/Pictures
As you have experienced, the writing /shares/Public/‘Shared Pictures’/Pictures is wrong. You should either write:
"/shares/Public/Shared Pictures/Pictures"
or
/shares/Public/** Shared\ Pictures/Pictures**
The use of the backslash character \ before a special character like space to cancel its effect (herein separating command line arguments) is called escaping the character.
Now, to solve your problem (I believe you have a terminal open on your mac computer), you should write:
Ok. I see. Sorry for my reply. As the use of quotes and backslashes are pretty basic stuffs, almost always required, I assumed you had little experience. Sorry.
However, I totally agree with you on rsync. I use it to automatically replicate one MBL to another through my home network. Also when I need to start a copy and know that I will not be able to complete it owing to time constraints. rsync allows me to stop and resume later. But, beware, that despite what is advertised, rsync cannot copy everything about the files on your MAC. There may be data losses on rare and occasional situations.
TIP :
As a MAC user, you could greatly benefit of the following combination :
