Router dead. using ethernet direct to PC
… but I cant connect to the drive !
I can acess the config pages but not map the drive.
going round in circles trying to get anything :dizzy_face:
I’ve run out of ideas now. The pc knows there is something connected but it wont connect to it.
What do I need to do  ?
thanks
Connecting a ethernet cable directly to a computer is not supported.  However, you must have your pc set to DHCP, and you must reboot, then you should be able to map to your shares.
