Round corner for posters
i want to be able to give the poster cover art; on left the same round corners as cover art on right ( screenshot )
here is the code:
<image image="@@poster" x="44" y="131" w="243" h="364" scale="100" scale_type="pan" align="top" bg="1"/>
i made a rounded corner poster art, but it still comes out as square.
so if i have SMP firmware 2.01.86 i should update the firmware to get the rounded corners?
so i renamed the cover art to .jpg and I get white corners.
i upgraded to 2.02.32 and this is what I get when i change back to a png…
the iron-man should have rounded corners like the one on right but as you can see it does not fit properly
how about this
how can I take the image at the right and use it for the poster art…
dunno, the PNG to JPG trick worked with 2014 WDTV Media Player Firmware 1.02.17
any version before that, and it won’t work.
WD disabled it on the WDTV Live Hub after firmware 2.07.17 and it has never worked on the SMP[quote=“Blackbeard1970, post:5, topic:143265”]
[/quote]
don’t understand … the image on the right and left is “poster art”
