“Clean Debian” - is a " Debian v7.2 / Wheezy" for armhf. Only ssh installed. Its a “base system” for do what you want “From scratch”. (Install omv or webmin. Or install all services like Samba and configure all via configs w/o gui)
There is no WD integration. You can use BTSync and/or OwnCloud instead.
My firmware much stable, provide more options, but some software not optimized for our hardware, so work slower (But Transmission works faster. idk why)
xxxxx:~# apt-get install ffmpeg
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ffmpeg : Depends: libav-tools but it is not going to be installed
Depends: libavdevice53 (>= 6:0.8.3-1~) but it is not going to be installed
Depends: libavfilter2 (>= 6:0.8.3-1~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I was wondering, how could i make the pip to work in python. Can you guys help?
WDMyCloud:~# apt-get install python-pip
Reading package lists... Done
Reading state information... Done
python-pip : Depends: python-pkg-resources but it is not installable
Depends: python-setuptools (>= 0.6c1) but it is not installable
Recommends: python-dev-all (>= 2.6) but it is not installable
Recommends: build-essential but it is not going to be installed
WDMyCloud:~#
Thanks for fixing the python-pip. It helped me a lot.
I have also an issue installing build-essential.
Am I approaching in correctly?
WDMyCloud:~# apt-get install build-essential
build-essential : Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: g++ (>= 4:4.4.3) but it is not going to be installed
Regarding my issue installing build-essential above:
I started to track down missing packages:
WDMyCloud:~# apt-get install -s build-essential
libc-dev
WDMyCloud:~# apt-get install -s g++
g++ : Depends: g++-4.6 (>= 4.4.7-1~) but it is not going to be installed
WDMyCloud:~# apt-get install -s g++-4.6
g++-4.6 : Depends: libstdc++6-4.6-dev (= 4.6.3-14) but it is not going to be installed
WDMyCloud:~# apt-get install -s libstdc++-4.6-dev
E: Unable to locate package libstdc++-4.6-dev
E: Couldn't find any package by regex 'libstdc++-4.6-dev'
It seems the “Black Pete” is the ‘libstdc+±4.6-dev’.
Do you think this was the root of the problem?
When tracking the libc-dev and libc6-dev packages dependencies with install -s i found no other missing packages.
There here was a typo in my previous post between ‘libstdc+±4.6-dev’ and ‘libstdc++6-4.6-dev’. That package is obviosly in the repo as you say. My bad.
My current assumption of the root of the problem is version mismatch of libc6 and others
WDMyCloud:~# apt-get -s install libc6-dev
libc6-dev : Depends: libc6 (= 2.13-38+deb7u8) but 2.17-93 is to be installed
Depends: libc-dev-bin (= 2.13-38+deb7u8) but 2.17-93 is to be installed
WDMyCloud:~# dpkg -l|grep libc6
ii libc6:armhf 2.17-93 armhf Embedded GNU C Library: Shared libraries
I wouldn’t be afraid to experiment (install -f or upgrade or maybe sid repo?) but currently I have only remote access to MyCloud. It should have the latest firmware installed (4.01.03.421)
