How do I install packages in SID repository? For example after I edited the sources.list and install transmission-daemon, the 2.52 version was installed. Thanks for any help.
demon_fox wrote:
sorry but faced the issue with ffmpeg
I might be wrong, but may be this has to do with:
marianowadel wrote:
Though libavdevice53 is available, it itself has unmet dependencies:
libavdevice53 : Depends: libcdio-cdda1 (>= 0.83) but it is not installable
Depends: libcdio-paranoia1 (>= 0.83) but it is not installable
Depends: libdc1394-22 but it is not installable
Depends: libjack-jackd2-0 (>= 1.9.5~dfsg-14) but it is not installable or
libjack-0.116 but it is not installable
Depends: libpulse0 (>= 0.99.1) but it is not installable
Depends: libxext6 but it is not installable
Depends: libxfixes3 but it is not installable
Same goes for libavfilter2, which itās also available but has unmet dependencies:
libavfilter2 : Depends: libopencv-core2.3 but it is not installable
Depends: libopencv-imgproc2.3 but it is not installable
Dependenciesā¦ Againā¦
I run remake for all packages. Wait a ~day or twoā¦
Your work is highly appreciated dude! Excuse us for being so demanding :wink:
What to I have to do to also get apt into my EX2?
I would like to install dlna but cannot use the steps in here as apt does not seem to be installed (no apt-get, not etc/apt).
Thanks,
florin
Hi guys.
IĀ“m new user and use any product from WD (HDDs, routers and now MyCloud). Sorry for my english IĀ“m from Spain
Well IĀ“m an amateur Linux user (Ubuntu-debian) and want to start with my new WD MyCloud 4Tb.
First active SSH mode
Use my OSX terminal to start
First replace default repos ā echo ādeb http://anionix.ddns.net wheezy-64k mainā > /etc/apt/sources.list
My questions:
apt-get upgrade to update all versions software in this device, It doesnĀ“t function? not a good comand? I think that havenĀ“t permissions
Is it easy to install transmision client and web browser using this repo? (Any guide?)
Does It exist any guide to known what programs are compatible? Or install mode
Try to install its manually:
Use wget to dowload apt, run dpkg -i *.deb for install it.
Download all dependencies and install it too.
Be ready to get a brick
GoldFran wrote:
Hi guys.
- apt-get upgrade to update all versions software in this device, It doesnĀ“t function? not a good comand? I think that havenĀ“t permissions
- Is it easy to install transmision client and web browser using this repo? (Any guide?)
- Does It exist any guide to known what programs are compatible? Or install mode
Yes, you can run apt-get update && apt-get upgrade from my repo. But some of packages cant be updated because its marked as dependencies of wd-nas package (Need edit dpkg library and remove all wd-nas info)
Web browser?
For install transmission - just run this:
apt-get update
apt-get install transmission-daemon
sed -i 's/USER=debian-transmission/USER=root:users /g' /etc/init.d/transmission-daemon
/etc/init.d/transmission-daemon stop
nano /etc/transmission-daemon/settings.json
Change settings here (Download dir, rpc-user/pass etc. - use search on this forum)
Save - [ctrl] + , type āyesā, [enter]
Run transmssion with new settings:
/etc/init.d/transmission-daemon start
Use this for easy control: https://code.google.com/p/transmisson-remote-gui/downloads/list
* All software in my repo compatable for v4 firmware.
You see
WDC:~# apt-get update && apt-get upgrade
Ign http://anionix.ddns.net wheezy-64k Release.gpg
Get:1 http://anionix.ddns.net wheezy-64k Release [2749 B]
Ign http://anionix.ddns.net wheezy-64k/main armhf Packages/DiffIndex
Get:2 http://anionix.ddns.net wheezy-64k/main armhf Packages [426 kB]
Ign http://anionix.ddns.net wheezy-64k/main Translation-en
Fetched 428 kB in 6s (62.2 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages have been kept back:
coreutils
The following packages will be upgraded:
apt apt-utils debian-archive-keyring dpkg e2fslibs e2fsprogs file
fontconfig-config gnupg gpgv gzip initscripts keyutils libapt-inst1.5
libapt-pkg4.12 libdbi-perl libdbus-1-3 libexpat1 libfontconfig1 libgcc1
libgcrypt11 libglib2.0-0 libglib2.0-data libgnutls26 libjpeg8
liblocale-gettext-perl libmagic1 libss2 libswitch-perl libtasn1-3
libtext-charwidth-perl libtext-iconv-perl libustr-1.0-1 login lsof
openssh-client openssh-server passwd perl perl-base perl-modules python2.7
python2.7-minimal sed sysv-rc sysvinit sysvinit-utils ttf-dejavu-core tzdata
util-linux wget
51 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
11 not fully installed or removed.
Need to get 9477 kB/35.2 MB of archives.
After this operation, 1008 kB disk space will be freed.
Do you want to continue [Y/n]? Y
WARNING: The following packages cannot be authenticated!
dpkg libgcc1 e2fsprogs gzip login libswitch-perl lsof perl perl-base
perl-modules sed sysvinit sysvinit-utils sysv-rc initscripts tzdata
util-linux libapt-pkg4.12 gpgv debian-archive-keyring gnupg apt e2fslibs
libss2 libustr-1.0-1 libapt-inst1.5 liblocale-gettext-perl libgcrypt11
libtasn1-3 libgnutls26 file libmagic1 libdbus-1-3 libexpat1 ttf-dejavu-core
fontconfig-config libfontconfig1 libglib2.0-0 libjpeg8 passwd apt-utils wget
libtext-charwidth-perl libtext-iconv-perl openssh-server openssh-client
keyutils libdbi-perl libglib2.0-data python2.7 python2.7-minimal
Install these packages without verification [y/N]? Y
Ā But donĀ“t install anything.
-Ā How can I edit dpkg library and remove all wd-nas info? If I canĀ“t edit this info, I canĀ“t upgrade it.
EDIT: I suppose that is this:Ā
rm -f /var/lib/dpkg/info/wd-nas.*
When I say āweb browserā I mean this ā Ā Use this for easy control:Ā https://code.google.com/p/transmisson-remote-gui/downloads/list
When I solve upgrade problem, install transmission
EDIT 1: Yeah
Hit http://anionix.ddns.net wheezy-64k Release
Hit http://anionix.ddns.net wheezy-64k/main armhf Packages
coreutils
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
WDC:~#
Ā Reboot and now install transmission!
Hi.
I have a problem!!!Ā
When I upgrade and then since the UI reboot WD My Cloud, the LED status ItĀ“s solid whiteā¦ 15 min agoā¦ What happen?
Official guide:Ā
Initializing ā White Solid ā device has begun loading the Operating System (OS).
idk. Need UART or something to see whats happend on device.
One thing: After update - something cant start and sustem freezes.
Hi again.
5 hours ago and LED stay on solid yet
I did the following:
1.- I started my WD MyCloud normally today.
2.- I started SSH console with my OSX terminal.
3.- Only have your repositories, erase nas.info, update and upgrade:
WDC:~# rm -f /var/lib/dpkg/info/wd-nas.*
4.- System update OK and check again all are update:
coreutils
5.- Reboot from UI normally, system do not freeze on UIā¦ in SHH appear this, when device was reboot:
Broadcast message from root@WDC (Tue Jan 13 13:36:43 2015):
The system is going down for reboot NOW!
Write failed: Broken pipe
6.- the system never started up again
7.- In 5 hours ago, donĀ“t touch this device, donĀ“t reboot, donĀ“t reset with paperclipā¦ nothing, waiting your wordĀ
What happen??
Ok manā¦
Power off and then power on and the same with a paperclip press and hold reset button.
Now, I suppose that the unit reboot completly and late a few hours will finish and I hope that blue solid LED beginā¦ If do notā¦ I will think to send it to my shopā¦ This product has 2 days in my home this shop change to other unit I think
PS: When I fully restore with paperclip at 40 secā¦ In few minutes, the browser show this but non password valid (admin or welc0me or black or nothingā¦) Then, this screen desappear and show 404 error.
Ā
PS1: This device has ping, you see:
iMac-de-Francisco:~ GoldFran$ ping 10.197.0.40
PING 10.197.0.40 (10.197.0.40): 56 data bytes
64 bytes from 10.197.0.40: icmp_seq=0 ttl=64 time=0.948 ms
64 bytes from 10.197.0.40: icmp_seq=1 ttl=64 time=0.276 ms
64 bytes from 10.197.0.40: icmp_seq=2 ttl=64 time=0.298 ms
64 bytes from 10.197.0.40: icmp_seq=3 ttl=64 time=0.193 ms
--- 10.197.0.40 ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.193/0.429/0.948/0.302 ms
If a few hors pass tonight (10-12 hours more or less) and this device isnĀ“t okā¦ I go to my shopā¦Ā
Clear browser cache and coockies or use another browser.
Maybe Apache2 after upgrade loose WDās configs and try to show defaultĀ āHello worldā page. (/UI not present by default, so you got 404 error)
WD continius deadā¦
browser say:
No se puede cargar la pĆ”gina web porque el servidor no ha enviado ningĆŗn dato.
CĆ³digo de error: ERR_EMPTY_RESPONSE
GoldFran wrote:
WD continius deadā¦
browser say:
Wowā¦
SSH access? (Try to downgrade firmware or reinstall it by my Autoinstall script)
Please,Ā open a new thread and discuss this issue somewhere else, Iāll be glad to help.
Iām being flooded with mails because Iām subscribed and this posts are off-topic.
marianowadel wrote:
Please, open a new thread and discuss this issue somewhere else, Iāll be glad to help.
Oh, sorry.
Ok, news: ffmepg + all libs now available.
ok, not problem because IĀ“m send my unit to shop so I hope in 2 days had a new device
PS: non-ssh access, only ping
I suppose getting apt would require special repository for arm+64k packages.
Is there such a repository somewhere?
Hello Fox_exe
can I use your repository with the latest firmware which is based on jessie not wheezy?
Best regards
Andrew
