demon_fox wrote:
Hello
I’m trying to install ffmpeg from your great rep, seems some dependencies are missed
WDMyCloud:~# apt-get install ffmpeg
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ffmpeg : Depends: libav-tools but it is not going to be installed
Depends: libavdevice53 (>= 6:0.8.3-1~) but it is not going to be installed
Depends: libavfilter2 (>= 6:0.8.3-1~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Same here, trying to add a script to run when Transmission finishes a .mkv download that transcodes the downloaded file’s audio to make it Chromecast compatible, but need either ffmpeg or newer avconv. Thanks!
Edit: Though libavdevice53 is available, it itself has unmet dependencies:
libavdevice53 : Depends: libcdio-cdda1 (>= 0.83) but it is not installable
Depends: libcdio-paranoia1 (>= 0.83) but it is not installable
Depends: libdc1394-22 but it is not installable
Depends: libjack-jackd2-0 (>= 1.9.5~dfsg-14) but it is not installable or
libjack-0.116 but it is not installable
Depends: libpulse0 (>= 0.99.1) but it is not installable
Depends: libxext6 but it is not installable
Depends: libxfixes3 but it is not installable
Same goes for libavfilter2, which it’s also available but has unmet dependencies:
libavfilter2 : Depends: libopencv-core2.3 but it is not installable
Depends: libopencv-imgproc2.3 but it is not installable
I believe that wdmcserver uses ffmpeg, but I couldn’t find any additional info on this, nor could I find the ffmpeg library within the My Cloud’s filesystem.
Cheers and thanks for your time and great job
