Replicate MBL system for installation tests purpose
Is it possible to create a clone from my MBL system to a virtual machine so i can test some installations?
Thanks in advance.
You’d have to disassemble the unit and image the drive for that, and you’d also need a PowerPC emulator.  So it’s technically possible but it’ll void your warranty and I basically don’t recommend it at all whatsoever.
PowerPC emulator? Can be done with virtual box?
