Where can I get a replacement UK power supply for my MyBook (WD3200|032) and is it a standard one?
Can anyone recommend an inexpensive but reliable (v important) WD replacement for the Seagate drive I foolishly bought that didn’t last 8 months and do they have any tips on how to make a drive last longer / take care of it?
You don’t know if it’s possible to order a power supply online by any chance do you?
One of the reasons I think the Seagate one packed in so quickly is because I had it plugged in permanently but one of my friends has said that it’s best not to do this, so I just need a small external that’s as reliable as possible - it doesn’t need to be large as I don’t have that much data - reliability is the main thing.
I only turn mine on when I use them. I’ve got a My Book Pro II that that a functional power switch. The power switches on the other two sadly only work with Smartware which I didn’t install. I plugged those into a separate powere strip to make it easier to turn on and off. I leave the USB cables plugged in.
