Replacement parts for My Book Duo
Hi
A few days ago, one of my WD ‘My Book Duo’ would not power up… even though I connected to a power supply & cable of my other ’ My Book Duo’ which works fine
I can only assume something as blown on the circuit board
Can I obtain a new circuit board and power adapter/cable for my faulty unit?
If you have a unit with a defective circuit board then I recommend you get the drive replaced. I dont recommend trying to repair it since it may damage the drive even more and make any data you have on it irrecoverable.
If you have data that you need to recover then I recommend you contact a data recovery company.
http://support.wdc.com/warranty/datarecovery.aspx?lang=en
