I have a HP 600PRO SFF desktop that was given to me. It currently has a 250Gb hard drive in it. The current hard drive is a seagate ST3250318AS. If the info I found is correct, it just states SATA 3Gb/S NCQ (not sure what that means).
I was looking at the black 1 TB drive with a 64Mb cache, but noticed they are a SATA III 6Gb/S. Will this work for me? I’m confused about the SATA types and SATA cable fitting the drives. I will be doing a fresh installation of Windows 7 or Windows 8.
