I need to replace the cooling fan for my EX2100. The spoilt fan is a SUNON PF70251VX-Q02U-S99 fan DC12V 2.46W.
Can I use this one I found: SUNON PF70251VX-Q000-S99 fan DC12V 3.7W?
Or are there others more suitable? The original model, I fear, has been obsoleted
Thanks!
I too, would be grateful to know whether this fan SUNON PF70251VX-Q000-S99 fan DC12V 3.7W would be suitable for the EX2100 as the model SUNON PF70251VX-Q02U-S99 fan DC12V 2.46W can hardly be found on any site.
i’ve seen this one on ebay if it helps https://www.ebay.co.uk/itm/1pcs-SUNON-PF70251VX-Q02U-S99-7025-12V-2-46W-4-wire-cooling-fan/143776006322?hash=item2179b7c0b2:g:6OwAAOSw7blffoNV
Interested to see if what you found worked and if so what did you use? Same problem with my fan going bad and looking for a replacement.
Thank you
