Hi all,
I have a G Speed Q 12TB and one of the drives is flashing amber and therefore needs to be replaced. As this is a discontinued product can I simply purchase an Hitachi Ultrastar 7200 RPM 3Gbit SATA drive from Ebay, fit it into the slide and use that?
I’m simply confirming that there’s nothing ‘special’ about the WD supplied drives?
Thanks,
Tony
