My cloud mirror is on an other router. Now I have to reeastablish my connection to the drive by hand on my android eeh things. Now I need an activation code (12 digits). How di I get such a code?
Hi bvoostveen,
There is no need to use any activation code to establish a connection with new router. You need to reset the network configuration back to DHCP and setup the My Cloud Mirror using the Dashboard. You can have a look on below KBA for more details:
https://support.wdc.com/knowledgebase/answer.aspx?ID=17779&lang=en
