Hi.
First of all, cheers form Chile (or Chili), and second, sorry for my Bad English… I learned just reading and playing Online…
Third, I would like to thanks everyone that has made/update any guide to upgrade/fix/or we My Cloud First Gen.
My serious problem is:
I bought a My Cloud 2 TB like… 1-2 years ago? And suddenly (I don’t know if my maid drop it ) started with persistent solid red light. After various reboots, it did not work. So Reading I thought that my HDD is broken so I bought another (similar NAS drive) WD 2 Tb.
I have done all the steps that I have searched but even if the IMGS are correct, it won’t turn blue. So I would like for some help, to start over.
I have done the same process, it’s a my cloud first gen.
When I finish doing it I insert the HDd to my cloud plate, power it on,
wait like 20 mins and stills red
Which unbricking process did you use? When unbricking make sure to follow the first gen unbrick directions exactly. It is also wise to perform a 40 second reset after performing all the unbricking steps.
Often a red light after unbricking means one of teh steps wasn’t followed exactly. This may include using the proper values when partitioning the hard drive for the first gen firmware. One cannot use the second gen unbrick process to unbrick a first gen My Cloud just as one cannot unbrick a second gen My Cloud using the first gen unbrick process.
