RED light... need help
I am trying everything and i cannot figure it out… i am not an expert and need help.
Model: ATA WDC WD30EFRX-68E (scsi)
Disk /dev/sda: 3001GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
3 15.7MB 528MB 513MB linux-swap(v1) primary
1 528MB 2576MB 2048MB ext3 primary raid
2 2576MB 4624MB 2048MB ext3 primary raid
5 4624MB 4724MB 99.6MB primary
6 4724MB 4824MB 101MB primary
7 4824MB 4826MB 1049kB primary
8 4826MB 4828MB 2097kB primary
4 4828MB 3001GB 2996GB primary
(parted)
thats what i get and there is no file system “ext4” on my largest partition… how can i fix it ???
I recommend you contact support directly.
Contact WD
Another way:  http://community.wd.com/t5/WD-My-Cloud/Rebuild-your-My-Cloud-or-upgrade-the-HDD-on-it/td-p/675109
