Hi All,
So I got the red light of hard drive death and my duo is in raid 1 mode. How do I know which drive is bad? How do I get the information off the good drive so I can back it up before the bad hard drive is replaced?
Thanks in advance,
Hi All,
Thanks in advance,
The UI will tell you which drive has failed. Look in the user manual under “replacing a drive.”
The red light may appear by different causes:
