Red light after hot swap
HI
can anyone help please?
I’ve a 56Tb EX4100 and hot swapped a failed drive (bay 4), but the red warning light is still on, all tests say it’s good and working fine, it is performing as it should, how do I get the red warning light to go blue?
TIA
Go to the Web Dashboard and check for error messages and disk issues.
If everything seems fine, you can system-only reset the NAS.
I recommend to backup your system config first.
  1. Create a backup of your system settings under Settings > Utilities > System Configuration
  2. System-only Reset the NAS: How to Pin Reset and System Only Restore My Cloud OS 5 Devices
  3. Restore the config under Settings > Utilities > System Configuration.
This helped me get rid of red LEDs with no further issues.
