I recently bought a dozen of WD Red drives, all those drives look the same, with the same MDL: WD60EFRX-68MYMN1, the same DATE: 20 OCT 2014.
But the firmware is NOT the same, two drives are 82.00A82, and all others are 80.00A80.
AND those 80.00A80 are running at SATA 3Gbps with NCQ not supported!
AND one of 82.00A82 is running at SATA 6Gbps with NCQ enabled, the other one is also running at 3Gbps without NCQ.
Why? What’s happened?
There are some IDENTIFY DEVICE result data.
First one, firmware revision 80.00A80.
0x00000000 7a 42 ff 3f 37 c8 10 00 00 00 00 00 3f 00 00 00 zB.?7ネ......?...
0x00000010 00 00 00 00 57 44 2d 57 58 4c 31 48 38 34 44 48 ....WD-WXL1H84DH
0x00000020 44 50 5a 20 20 20 20 20 00 00 00 00 00 00 38 30 DPZ ......80
0x00000030 2e 30 30 41 38 30 57 44 43 20 57 44 36 30 45 46 .00A80WDC WD60EF
0x00000040 52 58 2d 36 38 4d 59 4d 4e 31 20 20 20 20 20 20 RX-68MYMN1
0x00000050 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80 ..
0x00000060 00 40 00 2f 01 40 00 00 00 00 07 00 ff 3f 10 00 .@./.@.......?..
0x00000070 3f 00 10 fc fb 00 00 01 ff ff ff 0f 00 00 07 01 ?..・・...........
0x00000080 03 00 78 00 78 00 78 00 78 00 00 0d 00 00 00 00 ..x.x.x.x.......
0x00000090 00 00 00 00 00 00 00 00 06 84 00 00 40 00 40 00 .........・..@.@.
0x000000a0 fe 01 00 00 69 70 01 7e 23 41 69 70 01 be 23 41 ....ip.~#Aip.セ#A
0x000000b0 7f 00 00 00 00 00 00 00 00 00 00 00 fe 80 00 00 ................
0x000000c0 00 00 00 00 00 00 00 00 80 62 a8 ba 02 00 00 00 .........bィコ....
0x000000d0 00 00 00 00 03 60 00 00 01 00 00 00 00 00 00 00 .....`..........
0x000000e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 40 ...............@
0x000000f0 18 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
0x00000100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00000110 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 ................
0x00000120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00000130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00000140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00000150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00000160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00000170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00000180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x00000190 00 00 00 00 00 00 00 00 00 00 00 00 35 30 00 00 ............50..
0x000001a0 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 ...@............
0x000001b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x000001c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x000001d0 00 00 00 00 01 00 00 28 00 00 00 00 00 00 00 00 .......(........
0x000001e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0x000001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a5 27 ..............・'
Looking at Word76(0x8406=1000 0100 0000 0110b) and Word77(0x0000), Gen3 & NCQ are NOT supported, and current negotiated speed is ZERO?
AND Word84(0x4123=0100 0001 0010 0011b) indicated WWN IS supported, but WWN field(Word108-111) in IDENTIFY DATA is INVALID, even if there is a WWN printed on the drive’s case:50014EE20A80F545.
Second one, firmware revision 82.00A82 running at 3Gbps with NCQ disabled.
0x00000010 00 00 00 00 57 44 2d 57 58 32 31 44 42 34 31 53 ....WD-WX21DB41S
0x00000020 4e 58 4a 20 20 20 20 20 00 00 00 00 00 00 38 32 NXJ ......82
0x00000030 2e 30 30 41 38 32 57 44 43 20 57 44 36 30 45 46 .00A82WDC WD60EF
0x000000a0 fe 01 1f 00 69 70 01 7e 23 41 69 70 01 be 23 41 ....ip.~#Aip.セ#A
0x000001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a5 1e ..............・.
Word76(0x8406=1000 0100 0000 0110b) : Gen1,Gen2 are supported, Gen3, NCQ are not supported.
Word77(0x0000): current negotiated speed is ZERO.
Word84(0x4123=0100 0001 0010 0011b): WWN is supported.
Word108-111(01 00 00 00 00 00 00 00): invalid WWN
The last one, firmware revision 82.00A82 running at 6Gbps with NCQ enabled.
0x00000010 00 00 00 00 20 20 20 20 20 57 44 2d 57 58 32 31 .... WD-WX21
0x00000020 44 31 34 30 36 35 38 39 00 00 00 00 00 00 38 32 D1406589......82
0x00000090 00 00 00 00 00 00 1f 00 0e 9f 06 00 4c 00 40 00 .........・..L.@.
0x000000a0 fe 03 1f 00 6b 74 61 7d 33 67 69 74 41 bc 23 67 ....kta}3gitAシ#g
0x000000b0 7f 00 6f 81 6f 81 00 00 fe ff 00 00 00 00 08 00 ..o・o・..........
0x000000c0 00 00 00 00 a0 86 01 00 b0 f4 a0 ba 02 00 00 00 .....・..ー・.コ....
0x000000d0 00 00 00 00 03 60 00 00 01 50 e0 4e 37 59 08 5f .....`...P・N7Y._
0x000000e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1c 40 ...............@
0x000000f0 1c 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
0x00000100 21 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 !...............
0x00000190 00 00 00 00 00 00 00 00 00 00 00 00 3d 30 00 00 ............=0..
0x000001b0 00 00 44 16 00 00 00 00 00 00 00 00 7e 10 00 00 ..D.........~...
0x000001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a5 68 ..............・h
Word76(0x9f0e=1001 1111 0000 1110b): Gen1,Gen2,Gen3,NCQ are both supported.
Word77(0x0006=0000 0000 0000 0110b): current negotiated speed is Gen3.
Word84(0x6733=0110 0111 0011 0011b): WWN is supported.
Word108-111(01 50 e0 4e 37 59 08 5f): WWN=50014EE059375F08.
In the 3Gbps 82.00A82 firmware’s MOD02, I found a date string “09-05-2014”.
In the 6Gbps version, the date string is “10-28-2014”, NOTE that the date on the drive’s case is “20 OCT 2014”.
How can i upgrade all those drive’s firmware to 6Gbps&NCQ enabled revision?
