I was unable to login to an old 1 Tmybooklive, so finally gave up and took it out of the plastic housing.
I’m using OSX, here is what I can view through a console / terminal
xxx-MacBook-Pro:~ userx$ diskutil list
/dev/disk0 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *251.0 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_APFS Container disk1 250.8 GB disk0s2
/dev/disk1 (synthesized):
0: APFS Container Scheme - +250.8 GB disk1
Physical Store disk0s2
1: APFS Volume Macintosh HD 97.6 GB disk1s1
2: APFS Volume Preboot 56.2 MB disk1s2
3: APFS Volume Recovery 522.7 MB disk1s3
4: APFS Volume VM 1.1 GB disk1s4
/dev/disk2 (internal, physical):
0: FDisk_partition_scheme *127.9 GB disk2
1: Windows_NTFS SD 127.8 GB disk2s1
/dev/disk3 (external, physical):
0: GUID_partition_scheme *1.0 TB disk3
1: Linux_RAID 2.0 GB disk3s1
2: Linux_RAID 2.0 GB disk3s2
3: Microsoft Basic Data 512.8 MB disk3s3
4: Microsoft Basic Data 995.6 GB disk3s4
xxx-MacBook-Pro:~ userx$ diskutil list | grep disk3
Any suggestions appreciated. I still have the case, and could try using it if there is a better option while using it.
many thanks
