I am new to mycloud. However I seem to be getting the feel for using the device!
I have shutdown my cloud through the dashboard function as I was finished using it, like you would a TV (should I just leave it on?). There are now no lights on the device and I cannot reconnect to it, as it is shutdown, not showing on network etc…
I am also having problems with WD quickview, I have installed the software, however, when trying to open it, I just get the blue spining waiting disk, this stops and then quickview does not open.
I know I can just pull the power cable out of Mycloud, put it back in, and then it will start up. But this is not exactly convenient if I power down and am not at home, to turn back on…
Is there a way in quickview to power the system back up again? How do I get quickview working; I am on a windows 7 computer.
Please advise…
Thanks,
Simon
